testing MrMC 3.0.5
KeyserSoze
Re: testing MrMC 3.0.5
Post by KeyserSoze » 26 May 2017, 18:33
Any chance for Legacy HDHomerun tuners for this go around? I'm probably harping or you're just trying to wait me out to see when I finally crack and go through the process of setting up a development environment again ;)
Post by davilla » 26 May 2017, 20:10
KeyserSoze wrote:
26 May 2017, 18:33
HAHAHAAA, maybe I'll crack 1st. Upstairs AC stopped working (some wires fell off, wtf ?) so I had to clear a path to attic to get up into it. :) Need to move older unit up there with newer device so I can tap off the off-the-air antenna.
Post by davilla » 26 May 2017, 20:11
Itzme1234 wrote:
26 May 2017, 17:13
2D Monoscopic Worked for me. Cool, I had no idea MrMc even gave us that option. Or all those other options with SBS 3D. I saw that post on the other forum also.
I tested 2D Monoscopic on tvOS and on Firetv.
The issue was not if they worked but if 3D MKV files are displayed as 2D Monoscopic ?
Post by amet » 27 May 2017, 06:19
version 3.0.5 (170527.350)
- scan library using libdsm
- default samba for SMB:// files
jabohn
Post by jabohn » 27 May 2017, 17:18
My shares stopped working after updating to this beta. Using libdsm, connecting to macOS Sierra 10.12.6 beta
I click on the share and it says "working" for a bit and then it pops up the password box. I put the password in but it just repeats the cycle. Everything worked fine last night when I was still running MrMC 3.0.4
Post by amet » 27 May 2017, 18:14
We have brought back smb1, check that you don't have that enabled... otherwise debuglog is needed to see what's wrong
jabohn
Post by jabohn » 27 May 2017, 18:17
If you mean "Force SMB v1" then no it's not enabled. I'll work at getting the debug log.
FYI - step 2 in the debug log instructions is wrong. I had to look at the screenshot to find it.
Post by amet » 27 May 2017, 18:27
That's why it's there :)
I'll look at the instructions, we have changed some things there
jabohn
Post by jabohn » 27 May 2017, 18:31
Here is the log
Debug Log
Post by timstephens24 » 27 May 2017, 20:42
26 May 2017, 17:04
Reported that bug displaying 3D MKV files as 2D Monoscopic is still not fixed. Someone care to verify ?
I made a file from one of my movies, and it doesnt work. It plays what looks like part of the left eye, but a zoomed in section.
