testing MrMC 3.0.5
testing MrMC 3.0.5
Post by davilla » 26 May 2017, 02:02
How to request Testflight access: Send an email to support@mrmc.tv with the subject "I see dead people", include your email address tied to device, which flavor (tvOS, iOS or GooglePlay). Those under the 3.0.4 testflight need not reapply.
Fair warning for tvOS, this series will eventually require 10.2 tvOS as we will be moving to 10.2 required SDK.
(20170526-30b9292)
fixed: when called to stop app, stop rendering
fixed: crash on exit. CGUITextureManager is a global and we have no clue when it gets destructed.
emby: add paradoid check to make sure view is not null
emby: if we come from a filter, path is already set and we dont know what type we are(and we dont need to set URL options)
emby: fix if there is only one item in emby list and we have mysql
core: darwin, switch over to objc using ARC
core: libdsm, bring back session caching and watch lib updates fly
core: libdsm, get paranoid about correct slashes in path
core: libdsm, host name in passwords.xml could be ip or netbios name, try both when authorizing
core: libdsm: check for errors during CDSMSessionManager::CreateSession instead of timing out
core: libdsm AuthenticateURL if mismatched hostname/ip
core: libsmbclient AuthenticateURL if mismatched hostname/ip
core: show sets when services are enabled in skin.mrmc
Revert "set DSM as default SMB service"
Revert "core: libsmbclient, remove socket options and use the server defaults"
Revert "smb: remove FORCEV1 setting, does nothing as we only support v1 :)"
backport: ZipManager: skip path traversalbackport: [3d] Avoid switching stereo mode based on current display mode
backport: fix aspect ratio for matroska containers for stereo modes
(20170528-6dd4285)
Revert: more smb changes
fixed, move program stream selection for m3u8 back to CDVDInputStreamFFmpeg, ffmpeg just takes too long
backport: trap App icons not being bitmaps
fixed: memory leak. thx montellese for the hints
backport: gles, if we have nothing to draw, do not try
(20170530-90b851b)
fixup: core: libsmbclient AuthenticateURL if mismatched hostname/ip
tryfix for emby set watched
emby: set media types correctly
core: droid, sllience logcat spew
core: rapidjson version bump from 1.0.2 to 1.1.0
core: DNSNameCache make sure passed servinfoin null
core: add back the other flavor of samba for android
core: fixed DEPRECATED_SMBC_INTERFACE path for libsmbclient
Re: testing MrMC 3.0.5
Post by cosmoxl » 26 May 2017, 02:08
26 May 2017, 02:02
8-)
Post by timstephens24 » 26 May 2017, 08:15
26 May 2017, 02:02
Oh hey, sweet. What's the focus for 3.0.5 testing?
Post by davilla » 26 May 2017, 12:52
timstephens24 wrote:
26 May 2017, 08:15
26 May 2017, 02:02
More underlying prep for new skin. Regression checking.
Move to full ARC for darwin, plus bumps to 10.2 SDK, plus (drum roll) tvOS remote.
Emby/Plex Collections.
Plex transcode (grrrr).
libdsm regressions (if any).
Everbrave
Post by Everbrave » 26 May 2017, 13:10
What do you mean by tvOS remote?
Post by cosmoxl » 26 May 2017, 13:12
Is this testflight that says "version bump" the same code as the last release?
Post by davilla » 26 May 2017, 13:15
cosmoxl wrote:
26 May 2017, 13:12
Very close to it. When we bump testflight versions, we push in for Beta testing right away. Once that new version is reviewed, new pushes to that version do not require a Beta review. We do this to get over the Beta review delay.
Itzme1234
Post by Itzme1234 » 26 May 2017, 14:09
Minor issue. My first visit to the tv show shelf had one poster blank, but the graphic disappear when I would highlight it. Return visits to the shelf had all the posters appearing correctly.
services - Plex client- transcode quality. That menu seems a bit confusing to navigate. Is 40 mbps the Max? Hard to tell when Im at the max and the min options. Actually All aspects of transcoding are confusing to me, in terms of whether I want to transcode or not, and when.
Enable transcode and 40 Mbps set... briefly tested a few 1080p movies and all is good. Then tried enable transcode off... all is still good.
I'll keep testing! Glad to see the version bump and can't wait to see new skin!
Post by davilla » 26 May 2017, 17:04
Reported that bug displaying 3D MKV files as 2D Monoscopic is still not fixed. Someone care to verify ?
Itzme1234
Post by Itzme1234 » 26 May 2017, 17:13
2D Monoscopic Worked for me. Cool, I had no idea MrMc even gave us that option. Or all those other options with SBS 3D. I saw that post on the other forum also.
I tested 2D Monoscopic on tvOS and on Firetv.
