testing MrMC 3.0.3
testing MrMC 3.0.3
Post by davilla » 07 Apr 2017, 12:10
How to request Testflight access: Send an email to support@mrmc.tv with the subject "Be Kind, Rewind", include your email address tied to device, which flavor (tvOS, iOS or GooglePlay).
Live for tvOS and Shield. iOS pending.
Enabled for GooglePlay Beta Testers only, https://play.google.com/apps/testing/tv.mrmc.mrmc
Enabled for Amazon FireTV2 only. Note, if you opted-out of Amazon marketing communications, you will not get the notification email.
Changes:
- plex: fixed 3D SBS detection
- homeshelf: various fixes
- homeshelf: support both recently added and in progress item on (skin dependent)
- emby: added new native emby client
Movies/TVShows and Music views are supported. Owned/Shared resources. Two ways to login, 1 ) Login by user/pass via browse by broadcast. local emby servers only. 2) Login by Pin. Supports owned/shared resources, also supported picking which shares you want to see. We do expect to find corner case issues :)
20170412-c5e5d10
- fixed, tvOS. Pause/Play using play/pause button did not dismiss OS screensaver
- core, added audio silence factor selector
- core: changed. HLS is a realtime stream, flag it as such
20170417-1588615
- emby client fixes, allow empty password (user/pass signin)
- emby/plex client fixes, base64 -> base64Url
- fixed OS screensaver for droid
- fixed, auto close OSD after 3 sec inactivity
20170419-0b29595
- emby: fixed partialy watched flag
- emby: refactor how we check emby items are valid
20170424-e6c4622
- emby: Nth pass at fixing watched status
- re-add allow .filepart video extension
- mysql: add SETTING_MYSQL_TIMEOUT setting to MySQL service
- core: silence dev logging
- core: fixed, some (GOPro) videos lie about ref frames needed
- core: remove ".." from root mediawindows that contain services
testflight 3.0.3 is closed now. Rolling towards a release.
Re: testing MrMC 3.0.3
Post by cosmoxl » 07 Apr 2017, 14:30
07 Apr 2017, 12:10
Pending for tvOS, iOS and Shield. Looking into Amazon devices.
Changes:
Why the subject "be kind, rewind" ?? :)
Since I don't use 3D or emby should I take part?
Post by davilla » 07 Apr 2017, 14:35
Subject lines: Started doing this with the last testflight series. Just Feeble attempt at humor and want to make sure that users are paying attention :) Plus makes email list sorting easier.
There are other changes besides the addition of a native Emby Client. Also willing users might want to be sure we did not mess up normal (sqlite/myslq) or native Plex Client usage :)
Post by cosmoxl » 07 Apr 2017, 14:45
07 Apr 2017, 14:35
OK, I just thought maybe something changed with rewind function in the app. :)
Email sent in.
Post by davilla » 07 Apr 2017, 16:37
HAHA, for those that remember renting video tapes (VHS/BETAMAX). There would be a sign on the store. "Be Kind, Rewind". As in please rewind your rented tapes before returning them. :)
tredman
Post by tredman » 07 Apr 2017, 17:23
I was a member of the previous beta for the shield, am I still in or do I need to rerequest?
Sadly I am old enough to remember 'Be kind, rewind'. I also remember being fined for not rewinding too!
Post by cosmoxl » 07 Apr 2017, 20:27
07 Apr 2017, 16:37
oh, I definitely remember it. and people renting VCRs too. weird time in history. industry has definitely made advances in producing electronics cheaper.
Post by davilla » 07 Apr 2017, 21:09
tredman wrote:
07 Apr 2017, 17:23
Yes please, do a new request. We purge out the previous testflight lists.
Post by davilla » 09 Apr 2017, 11:10
tvOS/GooglePlay testflights are live, iOS to follow in a few days.
Post by davilla » 09 Apr 2017, 11:16
09 Apr 2017, 11:10
A few notes:
Emby seems 2X slower than Plex to provide root media content lists. So we added local caching of "Movies" and "TVShows". The 1st pull will be 3-4 seconds, depending on number of items. Once pulled, these items will cache and be updated via the Emby websocket API. You can force a pull/update using the 'Update Library" button on the left side out (default skin).
You can trim the list of Emby servers in Emby Client settings, this feature will eventually show up for Plex Client.
