GooglePlay MrMC v3.0.0
Re: GooglePlay MrMC v3.0.0
Post by davilla » 06 Feb 2017, 16:51
timstephens24 wrote:Do you need anything more specifically beyond the logs I sent and the crashlogs when it dies?
nah, crashlogs and mrmc.log should be enough provided the stack trace in the crashlog has any decent info.
Post by davilla » 06 Feb 2017, 17:21
2017-02-06-089ebee update is live.
Post by timstephens24 » 06 Feb 2017, 17:38
Just sent you one for the new build. Was on the main screen and using the controller and hit the back button (B).
http://paste.ubuntu.com/23942258/
Post by timstephens24 » 06 Feb 2017, 17:43
And another from going from Movies (Plex backend) to the main screen. The log wasn't moved to .old so it's still just showing the one from the previous crash.
edit: probably just cache issue for the log. Recreated it crashing and here's the log: http://paste.ubuntu.com/23942296/
Post by timstephens24 » 06 Feb 2017, 17:48
I switched the skin to the default MrMC from Amber and playing around going in and out of Movies/TV Shows works without crashing, so I'm guessing it's something with the Amber skin that's causing those crashes.
Post by davilla » 06 Feb 2017, 17:53
Always using controller and the back button (B) ?
Post by timstephens24 » 06 Feb 2017, 17:55
If you mean does it always do it, it just did it the first time I launched. If you mean do I always use the controller, no I almost never do. I can't recreate it with the MrMC skin, but using Amber I can crash it by just navigating around.
Post by davilla » 06 Feb 2017, 18:08
timstephens24 wrote:If you mean does it always do it, it just did it the first time I launched. If you mean do I always use the controller, no I almost never do. I can't recreate it with the MrMC skin, but using Amber I can crash it by just navigating around.
If you nav around using remote in Amber, same crashing ?
tredman
Re: RE: Re: GooglePlay MrMC v3.0.0
Post by tredman » 06 Feb 2017, 18:28
Yes, I use the shield remote and have the same crashes with amber (mainly seems to relate to the back button)
Post by timstephens24 » 06 Feb 2017, 18:53
Yes same crashing regardless of remote.
