GooglePlay MrMC v3.0.0
tredman
Re: GooglePlay MrMC v3.0.0
Post by tredman » 06 Feb 2017, 11:04
I have seem similar, but for me its quite specific and only happens when I enable the Amber skin and use the plex library integration - the crash on startup tends to follow a crash when existing the plex tv library view (in amber).
I will try and re-create later and post a log
Post by davilla » 06 Feb 2017, 13:08
cosmoxl wrote:I've gotten several crashes of MrMC as it's starting up. The shield gives me the choice to start again or send feedback. MrMC's old nor current log contain the crash. To get you logs I'm guessing I'd need to use ADB?
yes, I use adbfire (osx) and a USB connect to fetch logs on devices that are cranky with adb over network on linux.
Post by timstephens24 » 06 Feb 2017, 13:49
I'm using Plex and Amber and still seeing the crashes, but seems to have gotten worse after the recent update.
Post by davilla » 06 Feb 2017, 14:00
timstephens24 wrote:I'm using Plex and Amber and still seeing the crashes, but seems to have gotten worse after the recent update.
startup or nav'ing around crashes ?
Post by timstephens24 » 06 Feb 2017, 14:03
Both
Post by cosmoxl » 06 Feb 2017, 14:37
so you don't think over network I can get logs? BTW, I'm using the default skin, not amber.
Post by davilla » 06 Feb 2017, 15:55
On one of my shields I can (do adb over network), on the other, it refuses :) Go figure.
Post by davilla » 06 Feb 2017, 16:03
crashlogs are desired. I have three at googleplay, two are M'eh, no usable info. the third has a decent stack trace and I've made some changes. another version is brewing.
Post by timstephens24 » 06 Feb 2017, 16:47
Probably from me, I sent a few.
Post by timstephens24 » 06 Feb 2017, 16:48
Do you need anything more specifically beyond the logs I sent and the crashlogs when it dies?
