tvOS testing 3.0.0 (170207.1553)
Re: tvOS testing 3.0.0 (170125.1503)
Post by amet » 01 Feb 2017, 16:54
davidvb wrote:It seems I haven't been added to the test pool yet. Is that correct?
added and notified on 25th Jan
Post by cosmoxl » 01 Feb 2017, 18:30
So back to the topic at hand. What's the latest with the Plex transcoding work? Last thing I asked about was if AAC quality could be improved since it seems (at least for tvOS) it wasn't possible to direct stream some audio codecs from Plex.
DirectPlay, of course works for those audio codecs (that's with transcoding turned off).
I'm guessing AAC quality is chosen by a quality factor and not a bitrate? This makes sense because the bitrate depends on the number of channels contained. If so, and if 1.0 is the max quality, I'd choose something like 0.9. That's just my opinion. I'm betting default quality factor is 0.5.
Post by amet » 01 Feb 2017, 18:34
I got swamped with other things and put audio bitrate lower on the list... I will get to it soon I hope
Still investigating how we can set that since I could not find any documentation on it
Everbrave
Post by Everbrave » 01 Feb 2017, 18:35
Everbrave wrote:
ios or tvOS? e-mail support@mrmc.tv again please, I thought I added everyone
Actually, I haven't been added either; sent more than once!
as per our mail conversation, I have added you into iOS testflight that has not been launched yet... this is tvOS testflight thread
I see, thanks :)
Post by cosmoxl » 01 Feb 2017, 18:52
amet wrote:I got swamped with other things and put audio bitrate lower on the list... I will get to it soon I hope
yeah, I've searched the web too. can't find anything. :(
Post by cosmoxl » 02 Feb 2017, 15:27
while I'm on the subject, this won't browse my NFS either. But, already added NFS works just fine.
Post by amet » 02 Feb 2017, 15:34
Mine could never browse NFS, I always had to manually enter the IP address... davilla says his shows up in browse... go figure
Post by davilla » 02 Feb 2017, 17:01
Increase the network timeout setting. I'd double it. Try that.
Re: tvOS testing 3.0.0 (170207.1553)
Post by amet » 07 Feb 2017, 18:20
changes since 3.0.0 (170125.1503)
- fixed, plex client. double start when transcoding.
- fixed, vc1 playback on some flavors.
- fixed, dvd playback with previews before main menu.
- fixed, 3d -> 2d mono
- fixed, crash when going home and updating home shelf
Post by cosmoxl » 07 Feb 2017, 19:56
amet wrote:changes since 3.0.0 (170125.1503)
still need to look at EAC3 on tvOS. testing with the hd-dvd test files (which you got from me via dropbox) EAC3 is glitchy. But, plays just fine on shield. I've tested with transcoding on and off. Either way, audio is direct streamed. Is the apple tv just not capable of playing EAC3?
the double start when transcoding seems to be fixed. :)
