iOS Version Topic is solved
Any Opacity skin issues go here
Ted377
iOS Version
Post by Ted377 » 04 Mar 2019, 21:26
In the iOS version, the logos have not yet been adapted Image
SET-TOP-BOX: Apple TV HD
FW: tvOS 13 (Beta 3)
Front-End: MrMC 3.8.1
SET-TOP-BOX: Apple TV 4K
Front-End: MrMC 3.9.0 (190713.1549)
NAS: QNAP TS-231P
Back-End: TVHeadend/PLEX
Re: iOS Version
Post by amet » 05 Mar 2019, 03:43
:( this is a packaging issue, we are looking into it ... thanks!
Start using Ariana Touch, opacity is leaving IOS :)
Ted377
Re: iOS Version
Post by Ted377 » 05 Mar 2019, 09:11
Oh no 😱 !! Opacity is the simpler skin for me. I'm not a fan of Ariana.
NAS: QNAP TS-231P
Ted377
Re: iOS Version
Post by Ted377 » 05 Mar 2019, 09:38
Another post would say that Opacity never dies.
I was so happy when I was able to use MrMC on my iPad. And I use Opacity on all my devices because I really love this skin and it's easy to use.
In addition, I can serve Opacity on the iPad with the "Kodi Remote" from the store.
Then I must say with great regret ... REST IN PEACE OPACITY 😢
NAS: QNAP TS-231P
Re: iOS Version
Post by amet » 05 Mar 2019, 10:37
Opacity stays as one of the skins on Apple TV and on android, on iOS we found that is a bit cumbersome to use on touch devices and that’s why Ariana Touch was created.
You should not have any issues using the remote on Ariana Touch, what issues are you seeing?
Ted377
Re: iOS Version
Post by Ted377 » 05 Mar 2019, 10:47
The Opacity Skin shows where I'm going. In ariana Skin, I only hear one click, but nothing is visualized.
And I would like to ask again for the preservation of the Opacity Skins for the iPad.
Ariana Skin is not an option for me.
Graphically, I find Opacity much simpler and clearer than Ariana.
For the iPhone it may make sense, but not on the iPad.
NAS: QNAP TS-231P
Re: iOS Version
Post by amet » 05 Mar 2019, 10:50
Ted377 wrote:
05 Mar 2019, 10:47
Will discuss with the team, no promises :)
Ted377
Re: iOS Version
Post by Ted377 » 05 Mar 2019, 11:02
05 Mar 2019, 10:50
Ted377 wrote:
05 Mar 2019, 10:47
Finally, I bought the version for iOS because it is a very good media center and I think Opacity really very successful.
It can therefore be said that Opacity played a decisive role in the purchase 😉
NAS: QNAP TS-231P
Re: iOS Version
Post by amet » 05 Mar 2019, 11:50
I disagree, but I only use it on iPhone
Ted377
Re: iOS Version
Post by Ted377 » 05 Mar 2019, 12:02
That's why I said; on the iPhone it makes sense 😉
Mainly I am dealing with the iOS version of the iPad.
I would really appreciate it if Opacity stays there 😊
NAS: QNAP TS-231P
