Ariana - what’s missing
Itzme1234
Post by Itzme1234 » 03 Apr 2019, 19:26
Let’s all please make a list of what we think needs attention in Ariana tvOS. Mine are just a start, and not in any order of priority.
As a Plex client, Ariana has good context sensitive menu options when you push and hold IF you are in the Movie or TV sub sections. That same push and hold opyion needs to be added to the main screen.
Options to Mark As Watched /unwatched on detail screen.
Movies should show extras for Plex subscribers.
TV shows should play theme songs (Pacinko said it was in development).
Live TV has a long pause before playing (using HD Homerun)
Access to the Plex Transcoder (if possible). Or an error message that tells the user if it’s isnt playing because of bandwidth, or a remote servers bandwidth limit.
Montoya
Re: Ariana - what’s missing
Post by Montoya » 03 Apr 2019, 19:49
You could post the above in Ariana subforum, to also involve users of the other MrMC platforms than tvOS :
https://mrmc.tv/forum/viewforum.php?f=36
Itzme1234
Post by Itzme1234 » 03 Apr 2019, 22:00
I ask the mods to please move this post there, as appropriate.
Post by amet » 04 Apr 2019, 03:13
Only movies extra would be part of Ariana skin, all other are core changes
logan_x50
Post by logan_x50 » 07 Apr 2019, 15:26
Genre Search
Some change to TV Episodes Home Shelf - Annoying to see a row of the same poster across the screen all the time.
H.Bear
Post by H.Bear » 08 Apr 2019, 04:29
I miss the 'Recommended Episodes' from other Kodi skins, which show the next episode of a series which you are watching.
Is this a python function/widget and therefore unusable in MrMC?
Is there a way to incorporate the 'In Progress' feature of the TV Shows submenu on the the home screen as this provides a similar feature?
Not the 'In Progress' which is currently on the home screen, which only shows episodes which have begun, but not been finished.
- Bear
Pacifism is a shifty doctrine under which a man claims the social benefits of the group without being willing to pay - and claims a halo for his dishonesty.
- Robert A. Heinlein
H.Bear
Post by H.Bear » 13 Apr 2019, 01:37
If you can tell me a 'yes' or 'no' I can decide whether to change to a different solution or wait.
Thanks,
- Bear
Post by amet » 13 Apr 2019, 04:39
On deck, Plex service has it
We can look into it for mrmc database
