information overlay
Any issues that are NOT Nvidia Shield or FireTV specific
theRCRH
information overlay
Post by theRCRH » 23 Aug 2018, 16:12
I've just moved from a firetv to an android box provided by my cable provider. The remote with the box doesn't have a secondary menu button like the firetv. I'm trying to figure out how I can get the file information overlay to pop up during video playback. I'm talking about the overlay that showed video format, audio format, cpu usage, etc.
I primarily use the Amber skin would be fine with having to use another skin if need be.
Thanks.
theRCRH
Re: information overlay
Post by theRCRH » 28 Aug 2018, 06:15
No one?
Anyone?
Post by amet » 28 Aug 2018, 10:13
Only way to activate is via webserver remote
Post by cosmoxl » 28 Aug 2018, 13:26
I use a firestick remote with my Shield via bluetooth. I wonder if the other firetv remotes would work?
theRCRH
Post by theRCRH » 30 Aug 2018, 00:16
28 Aug 2018, 10:13
That kinda sucks. I thing this remote has a pretty standard Android TV remote. Could an on screen control be added to a skin?
theRCRH
Post by theRCRH » 30 Aug 2018, 00:17
cosmoxl wrote:
28 Aug 2018, 13:26
I'll try pairing one of my FireTV remotes before I sell them off.
Thanks.
theRCRH
Post by theRCRH » 02 Sep 2018, 01:26
cosmoxl wrote:
28 Aug 2018, 13:26
Cosmoxl, how did you get your firestick remote to go into "pairing mode"?
BillyBudapest
Post by BillyBudapest » 05 Sep 2018, 20:53
Another vote to get this feature added.
Post by cosmoxl » 05 Sep 2018, 20:57
theRCRH wrote:
02 Sep 2018, 01:26
cosmoxl wrote:
28 Aug 2018, 13:26
wow, sorry I missed this.
I've always just gone to the settings, bluetooth remote section, and added there. If that doesn't work, try holding down the home button on the remote you want to add.
