Movie trailers from home screen
Fehritale
Post by Fehritale » 03 Mar 2019, 13:47
the feature movie trailers from home screen is not working correctly for me.
If I highlight a movie on the android mrmc channel, all I see is the loading circle. After a while the loading circle disappears and nothing happens. My expactations are that the movie trailer will start playing. The trailer feature inside MrMC works perfectlly fine.
I activated video preview and sound preview in the shield android setting.
It worked a while ago, should be version 3.7 but not sure, but I stopped using MrMC for while so i can't say when it stopped working.
Platform: Nvidia Shield Android TV with Shield Experience 7.2.2 (Android 8.0) and MrMC 3.8 Preview.
If a debuglog is required, please let me know. Not sure if you see anything in there, since it is from the android home screen and not inside MrMC.
Thanks in advance for your help guys.
Re: Movie trailers from home screen
Post by koying » 03 Mar 2019, 14:37
It's due to the latest Shield firmware, as far as I can tell.
Previously, you could play youtube url's from the home screen (aka the trailers), but it's broken now.
Fehritale
Post by Fehritale » 03 Mar 2019, 15:02
Thanks!
So again a change Nvidia did and not mentioned :roll:
Hopefully you guys find a workaround for that. I really liked that feature.
