controlling MRMC Topic is solved
eyosha
controlling MRMC
Post by eyosha » 18 Feb 2019, 10:54
I'm starting to use MRMC not just as video player, also as Radio player
the way I do this is pulling playlist file with stations URL's from smb share, MRMC play thosr fine.
but I do not want to open the TV to choose different station each time.
can I use Yatse / web interface / other methods to controll MRMC and choose different item in play list?
Can I do that even if MRMC runs and play the music when minimised?
thanks
Elad
Re: controlling MRMC
Post by davilla » 18 Feb 2019, 15:55
eyosha wrote:
18 Feb 2019, 10:54
thanks
Elad
Did you try it ?
eyosha
Post by eyosha » 18 Feb 2019, 19:45
I did. It did not go well via web interface, not because I couldn't connect but due to lack of features.could not get into files to fetch the playlist.
However now with yatse remote app all is well.
I can now use my shield also as radio player not just for movies.
Elad
