How do you stop playback on MRmC ?
eyosha
Post by eyosha » 17 Feb 2019, 07:42
Hello
So I bought Shield TV as My Sony TV great as it is can't pass ARC audio as of last Oreo update and even when it did, it was hit and miss.
Now once Installed MRmC on the shield all is smooth as a dream!! thanks for that MRmC team!
only one question though. how do I stop playback with the remote?
long press pause the video, short press brings the upper navigation option when I press bacj button it shows the play controll on the bottom but not always. Sometime I have to do that trick again in otder to see the bottom controlls,.
Hoiw can I fix this?
is there a shortcut to stop playback?
thanks
Elad
wdpcpa
Re: How do you stop playback on MRmC ?
Post by wdpcpa » 16 Mar 2019, 22:32
I use the voice command. Push the little microphone and say "Stop".
Post by cosmoxl » 16 Mar 2019, 22:40
just push the back button on the remote.
wdpcpa
Post by wdpcpa » 16 Mar 2019, 23:38
cosmoxl wrote:
16 Mar 2019, 22:40
What do you do for "pause". I have been using the voice command for that as well.
eyosha
Post by eyosha » 17 Mar 2019, 06:14
Thanks. Just noticed that for opacity skin you have also dedicated stop button. Ariena which I use now don't.
Anyway I use yatse to control MRmC from my phone so all is well.
Elad
