SapoMalo
Post by SapoMalo » 12 Feb 2019, 18:09
cosmoxl wrote:
11 Feb 2019, 20:34
3) TrueHD/Atmos tracks will not passthrough but DTS-HD Master/DTS:X does. While playing a TrueHD test file I turned off passthrough and PCM sound did work. Turning back on passthrough resulted in nothing input to my receiver.
edit: turning off IEC packed allowed TrueHD to play but it had moments of dropping out.
Exactly the same here with my setup and 11th February build...
With IEC off, severe drop outs with both TrueHD and DTS-HD MA btw
hieyemtim
Post by hieyemtim » 13 Feb 2019, 02:40
It would be so awesome if you could just copy your perfect pass-through code from SPMC Koying. I know it isn’t that easy but man every file works perfectly with SPMC’s Raw Android Passthrough. Thank you all, for your super hard work on this project. Can’t wait until we’ve got it working just like SPMC. Thanks to all of you who are working on developing this.
semperfixd
Post by semperfixd » 13 Feb 2019, 05:23
Is it possible to install the older version with Passthrough working along side this newer beta?
maglione66
Post by maglione66 » 13 Feb 2019, 22:17
Any news on the fix? Mrmc it is unusable now.
semperfixd
Post by semperfixd » 14 Feb 2019, 15:37
Installed the update. Atmos is displayed on the receiver now but it is completely broken. Getting dropouts and/or random mapping of speakers i.e. sound is coming from a different speaker than where it is supposed to come from. As a reference, it works fine on the Plex app on the shield TV.
Log new
https://pastebin.com/4PtJ2akJ
Post by koying » 14 Feb 2019, 16:43
in IEC? (Your log is partial)
semperfixd
Post by semperfixd » 14 Feb 2019, 17:20
koying wrote:
14 Feb 2019, 16:43
Toggling the option "Passthrough format is IEC packed" makes no difference.
SapoMalo
Post by SapoMalo » 14 Feb 2019, 21:51
Well, after a short check (a test file and 5 minutes for 3 different movies) seems that the Atmos passthrough issue has been fixed for me...
Atmos is recognized by the receiver, mapping seems ok and no drop outs (iec is packed).
As far as for now... If something changes, I'll report eventually...
Thanks for now
Post by cosmoxl » 14 Feb 2019, 23:19
Atmos works again for me in latest build but the other problems I've mentioned are not fixed. It would be good to know if they were supposed to be fixed for this build or not.
Post by koying » 15 Feb 2019, 00:04
No, this release is focused on fixing passthrough
