Can I add Weather to this Skin
Any Black Glass Nova skin issues
thomfam
Post by thomfam » 11 Jan 2019, 00:02
How do I add Weather to this skin?
I must have clicked on something in the settings as when I now open MrMC and go to this skin Weather opens up but without any info.
If weather isn't available, how can I turn this feature off and then go back to the list I had previously?
thomfam
Re: Can I add Weather to this Skin
Post by thomfam » 13 Jan 2019, 02:53
Managed to fix the MrMC Startup Screen. In the settings there is an option to choose your startup screen. I selected Home and now things are back to normal.
I still don't know if Weather is available for this skin. I haven't been able to find any info on 'extensions' for MrMC anywhere on the internet! Google search hasn't given me any joy at all.
Post by amet » 13 Jan 2019, 04:16
There is no extensions for MrMC, only the helper extensions that we pre-package.
Weather is not available
thomfam
Post by thomfam » 13 Jan 2019, 21:49
Thanks Amet, that is what I thought. I haven't messed around with MrMC for a while so that is what I remembered was the case. I thought maybe there had been some developments in the addon area.
Much appreciate the reply.
