Search movies with MRMC
Imhotep
Post by Imhotep » 30 May 2019, 19:08
Hello,
is it possible to search for movies in mrmc with emby DB? Unfortunately I can't do that :(.
If I'm looking for a movie, he won't find anything.
Re: Search movies with MRMC
Post by timstephens24 » 01 Jun 2019, 14:21
It just worked for me. Are you sure there's not a filter like only showing unwatched that's limiting your search?
##### SYNOLOGY 1815+ #####
