Emby server 4.0 - library folders on home screen
sylvio2000
Post by sylvio2000 » 21 Jan 2019, 19:02
In my movie library(emby server on Synology) I have added 2 folders: "HEVC" and "Filme". After upgrading to emby server 4.0 these 2 folders are shown inside MrMC on the home screen. I thought there went something wrong during the upgrade so I installed emby server 4.0 and MrMC from scratch. But that did not help.
I have tried Ariana ond Opacity. Both show these folders. Is it a bug?
Re: Emby server 4.0 - library folders on home screen
Post by timstephens24 » 21 Jan 2019, 19:55
Yeah I get them too. I posted in another thread my picture that shows it in Ariana.
##### SYNOLOGY 1815+ #####
Everbrave
Post by Everbrave » 22 Jan 2019, 14:52
This has always been the same in MrMC regardless the server version or the skin. My guessing is that MrMC points to the wrong place in Emby DB.
The issues withe MrMC and Emby have been discussed at several places in the forum; effectively, nothing has changed in Emby integration since a long while ago!
sylvio2000
Post by sylvio2000 » 24 Jan 2019, 09:49
For me, with emby server 3.x this was no problem.
Since emby server 4.0 this problem exist for me.
Montoya
Post by Montoya » 24 Jan 2019, 11:28
sylvio2000 wrote:
24 Jan 2019, 09:49
Well, this is strange, because in my MrMC Emby Client setup, I haven't experienced this in whole Emby beta branch of 3.6.0.x, 4.0.x and 4.1.0.x
Maybe it helps that everyone provides some info about their Emby setup:
- Emby Library types:
Movies, TV Shows
- Emby Library pointing to multiple folder branches for each library:
No
- How many Emby Movie libraries:
10
- How many Emby TV Shows libraries:
1
- Sign-in type Emby Client Service:
Manual
Please add other info that may help investigating this issue.
sylvio2000
Post by sylvio2000 » 24 Jan 2019, 16:12
2 Movies, 1 TV Shows
Yes. 1 movie library with 2 folders
2
1
Manual
Montoya
Post by Montoya » 24 Jan 2019, 16:41
Thanks @sylvio2000
At first it seems that Emby users are affected when they have a Movie library setup in Emby where multiple folders are assigned to that Movie library in Emby. Can you guys confirm @Everbrave & @timstephens24 ?
Because in my setup where I don't have this problem, each Emby Movie library is assigned to only ONE folder in Emby.
Post by timstephens24 » 24 Jan 2019, 20:35
Yeah that's what I said in my original post, it's when you have multiple folders set in Emby for one library.
sylvio2000
Post by sylvio2000 » 25 Jan 2019, 08:20
I can confirm this.
Without multiple folder in one library everything is OK !
sylvio2000
Post by sylvio2000 » 01 Feb 2019, 20:48
I just wanted to ask, if this a confirmed bug, which is being worked on?
