Issue with multiple profiles / users
sdmaged99
Post by sdmaged99 » 06 Nov 2018, 15:12
Hi All
Looking for some help
I have MrMC (which i am super impressed with!) on my Nvidia Shield TV and i have two user accounts inside the app called Adults and Kids, and then two accounts inside Emby with the same name
I have logged in with the Adults profile, and then connected to the Emby server via the services menu / Emby tab, located the Emby server on the LAN, and then entered the Adults username, which then shows all the correct movies and TV shows when i return to the main screen
However, if i then log off, and log in as Kids, and then set Emby up again, and log in as Kids inside there, when i log off and back on as Adults, the libraries no longer show, and i have to set it up again
This is then just a cycle i can't get out of.
Am i doing something wrong, as i would think this isn't an usual use case scenario? I want the kids to only see the kids emby libraries, and adults to see the adults ones
Many thanks
Montoya
Re: Issue with multiple profiles / users
Post by Montoya » 07 Nov 2018, 13:05
Have you setup MrMC in each profile for Emby in :
Settings>Services>Emby client>Emby Manual Sign-in ?
And have you created the MrMC profiles with standard settings, so that they use separate sources for Media Info/Sources ?
sdmaged99
Post by sdmaged99 » 07 Nov 2018, 17:16
Thanks for the reply
Yes, both users are signed in to the manual sign in with the correct username
Also the new MrMC profiles were created brand new with separate sources and settings for everything, i didn't "copy from default" on anything
Montoya
Post by Montoya » 07 Nov 2018, 17:34
Have you selected your Emby Server on MrMC Home screen ?
(in Opacity Skin, the most left icon on bottom screen, to switch Server source)
sdmaged99
Post by sdmaged99 » 09 Nov 2018, 23:45
Hmm, i'm not sure, ill check and come back to you asap
My wife was complaining that the tv shows in the bedroom were not synced with those in the lounge... (both have Emby, on two shields)
