IPTV not working
gogito75
IPTV not working
Post by gogito75 » 20 Dec 2018, 08:11
Hello! After upgrading to 3.7.1 on Xiaomi mi box 3 android oreo 8.0, high-definition IPTV works horribly. It often crashes after a few minutes of watching. I was trying to change the settings but there was no result. The app became unusable for me. Is there any solution?
https://share.icloud.com/photos/0jdB4JL ... HxdMJKyRRw
https://share.icloud.com/photos/0B3hPrN ... l44kebdRLQ
Re: IPTV not working
Post by amet » 20 Dec 2018, 17:25
Post by amet » 20 Dec 2018, 18:01
I cant access the second one
gogito75
Post by gogito75 » 20 Dec 2018, 18:02
Now?
Post by amet » 20 Dec 2018, 18:07
ok now, lets see what koying says, he is the master :)
gogito75
Post by gogito75 » 20 Dec 2018, 18:08
Nice! Thanks!
Post by amet » 20 Dec 2018, 18:13
can we use the link from the log to try to reproduce??
or see if you can download few minutes of the file using the browser and see if it triggers the same issue, then send it to us.. if we can reproduce, we can probably fix it :)
remove the log now please since the links are exposed
gogito75
Post by gogito75 » 20 Dec 2018, 18:19
I have MrMC on AppleTv, iPhone. I have no problems with them. I use a paid subscription for IPTV. There are limitations and I think you will not get the signal.
Post by amet » 20 Dec 2018, 18:20
try to pull a few minutes down using a browser or vlc on computer and see if you can reproduce on android.. if you can, we can test and try to fix
