DTS passthrough
DTS passthrough
Anyone having issue with a/v sync using DTS passthrough ? Maybe shows up after seeks ?
Re: DTS passthrough
yes i do even just pausing the video will make audio go out of sync
Re: DTS passthrough
mrchrister wrote:yes i do even just pausing the video will make audio go out of sync
details please. describe a) your audio setup, b) your mrmc audio setup and of course debuglog
Re: DTS passthrough
audio setup : Logitech z5500 connected via optical audio. The optical audio is connected to an HDMI spdif splitter. system is firetv 2.
mrmc is the only software that makes DTS pass through work. with spmc only DD works but white noise for DTS files.
here's a recent log
http://pastebin.com/anFymCQa
here's a recent log
Re: DTS passthrough
Thanks for fixing this by the way! DTS passthrough works great now in MrMc
