I was successfully using mrmc_env.properties in version 3.1, I upgraded to 3.2 and it stopped working. After the upgrade, I could not get to the main menu of MrMC. The app would either dark-grey screen forever or just quick exit.
I first tried to just clear cache at the Amazon FireOS level, but that had no effect. I did get MrMC working again by clearing cache AND data at the Amazon FireOS. However, there were no files in the /storage/sdcard1/Android/data/tv.mrmc.mrmc/files directory and MrMC was using the internal sdcard.
I moved the .mrmc directory from the 'files' directory on internal sdcard to the 'files' directory on the external sdcard1 and ensured that my mrmc_env.properties pointed at the sdcard1 location. Once again, I got grey-screen hangs or quick exits from the application.
What am I doing wrong?
mrmc_env.properties not working in 3.2
Re: mrmc_env.properties not working in 3.2
Humm, we changed nothing regarding mrmc_env.properties.
Did the FireTV OS update ?
megamob
So... the last OS update my FireTV received was over a month ago (September 21, 2017). I know that I set up MrMC initially the first week of October.
I haven't really done that much with MrMC yet, so I can try from scratch. Before I do, let's review the plan:
- uninstall MrMC
- delete mrmc_env.properties from the root of internal storage
- ensure the Android/data/tv.mrmc.mrmc directories on both internal and external sdcard storage locations are deleted
- re-install MrMC
- launch MrMC
- exit MrMC
- recreate mrmc_env.properties in the root of internal storage containing the single line
xbmc.data=/storage/sdcard1/Android/data/tv.mrmc.mrmc/files - move Android/data/tv.mrmc.mrmc/files directory from internal to external storage
- launch MrMC
