freeze frame
sashahouse
freeze frame
Post by sashahouse » 17 May 2019, 08:34
Good afternoon. there is a problem on apple tv 4 k. dear developers. when you view the sheet iptv within hours less time on any channel included proishodit freeze and then everything froze and there is no broadcast. how to deal with it. I changed playlists. the problem persists. the app is updated(the last it is up to date) the app is deleted and downloaded again. please solve the problem.
Re: freeze frame
Post by amet » 17 May 2019, 11:51
Debuglog please, but it all smells like a bad iptv feed
sashahouse
Re: freeze frame
Post by sashahouse » 17 May 2019, 12:39
I inserted different sheets and the effect is the same .
sashahouse
Re: freeze frame
Post by sashahouse » 17 May 2019, 13:14
stream going great not quadratic. and then once the picture is in freeze and freezes and hangs on the brake frame.
vrabac
Re: freeze frame
Post by vrabac » 17 May 2019, 20:56
amet did wrote you what he need to check your issue. Follow that link, enable Debug loging with components and paste it to some paste site and post here the link
Front-End: Apple TV 4K 64GB (AppleTV6,2 with TVOS 12.1.2) @ mrmc 3.8.1
Back-End: VDR 2.3.8 (vdr-vnsiserver 1:1.5.2.r15.g1fd5aee-1)
