Dolby Vision
Grencola
Re: Dolby Vision
Post by Grencola » 19 Jun 2019, 16:45
Morten1969 wrote:
19 Jun 2019, 08:44
when i demux the mp4 file it makes this HDR10 file
General
Complete name : C:\film\dv_el_out_1.h265
Format : HEVC
File size : 45.4 GiB
Video
Format : HEVC
Format profile : Main 10@L5.1@High
HDR format : SMPTE ST 2086, HDR10 compatible
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
what the, where'd the el+rpu go? what happens when you try and demux the mp4 in TSMuxer? it probably doesn't recognize get recognized. there HAS to be a way to demux the video track while retaining dv. I know when I demux the single layer LG demo files in TSMuxer it works just fine. must be an issue with the mp4 container. perhaps dolby mp4demuxer has a certain trigger you need to include to attach the el+rpu onto the video track while demuxing
Morten1969
Re: Dolby Vision
Post by Morten1969 » 19 Jun 2019, 17:01
Tsmuxer will not reconize the DV videofile and import just the audio.
Grencola
Re: Dolby Vision
Post by Grencola » 19 Jun 2019, 19:30
Morten1969 wrote:
19 Jun 2019, 17:01
Damn. I'll look more into what all mp4demuxer can do when I get home.
Grencola
Re: Dolby Vision
Post by Grencola » 20 Jun 2019, 00:47
Morten1969 wrote:
19 Jun 2019, 09:29
i have made a sample of Black Panther in mp4. It would bee great if this could play in mrmc.
https://filebin.net/10rl6l1mdyhdlzck
can't seem to download from this link
Morten1969
Re: Dolby Vision
Post by Morten1969 » 20 Jun 2019, 06:08
Grencola
Re: Dolby Vision
Post by Grencola » 21 Jun 2019, 03:30
Morten1969 wrote:
20 Jun 2019, 06:08
try this
thanks, that worked. yeah I get the same result as you. demuxing the mp4 seems to just strip off the metadata. it's interesting though, because it's only baselayer+rpu, whereas the single layer LG DV demo files are baselayer+el+rpu. so when you demux the LG demos you lose rpu but it still has baselayer+el dolby vision profile 5.06. but demuxing the mp4 reverts it back to profile 5.01 with no mention of dolby vision at all. I'm not sure how it can have dolby vision with only rpu and no enhancement layer, because I don't understand enough of how dv works. I do think I can multiplex it into x265 though, as it now supports Dolby vision, then I can add in hd-audio and strip out the ac3 since tsmuxer is a bust.
Re: Dolby Vision
Post by davilla » 22 Jun 2019, 18:17
and we have playback in MrMC (3.9.0) :)
videotoolbox codec for now as avfoundation codec is missing hev1 (in-stream sps/pps/vps)
Re: Dolby Vision
Post by davilla » 22 Jun 2019, 20:48
and we have avfoundation codec playback in MrMC (3.9.0) :)
2019-06-22 16:43:11.335756-0400 MrMC[1093:828602] Debug Print: FactoryCodec - Video: avf- - Opening
2019-06-22 16:43:15.033559-0400 MrMC[1093:828315] Debug Print: ------ Window Init (DialogBusy.xml) ------
2019-06-22 16:43:45.853464-0400 MrMC[1093:828602] Debug Print: FactoryCodec - Video: avf-h265 - Opened
2019-06-22 16:43:45.854893-0400 MrMC[1093:828815] Debug Print: CDVDVideoCodecAVFoundation::Process Started
2019-06-22 16:43:45.874913-0400 MrMC[1093:828315] Debug Print: CGUIInfoManager::SetCurrentMovie(smb://QNAP:445/Multimedia/Work/dolbyvision/dv_el_out_1.mov)
2019-06-22 16:43:46.493373-0400 MrMC[1093:828816] Debug Print: fps: 23.976024, pwidth: 3840, pheight: 2160, dwidth: 3840, dheight: 2160, colorrange: Limited, colorspace: bt2020nc, colortransfer: unknown
2019-06-22 16:43:46.493442-0400 MrMC[1093:828816] Debug Print: OutputPicture - change configuration. 3840x2160. framerate: 23.98. format: BYPASS
2019-06-22 16:43:46.493529-0400 MrMC[1093:828816] Debug Print: Display resolution DESKTOP : 3840x2160@ 59.94 - Full Screen (16)
2019-06-22 16:43:46.496402-0400 MrMC[1093:828816] Debug Print: displayRateSwitch request: refreshRate = 23.98, dynamicRange = DolbyVision
Some audio would be nice, lol;
Grencola
Re: Dolby Vision
Post by Grencola » 23 Jun 2019, 04:54
22 Jun 2019, 20:48
yay, that is awesome it works! it should have ac3 audio, just maybe not his sample though. but they're so simple to make with dvdfab's fancy gui and all. you should grab the trial ( https://www.dvdfab.cn/mlink/download.ph ... 1_x64_FULL ), you get 3 full conversions before you need a license, and give it a go on a dolby vision bdmv folder or uhd disc you have. then you can test it all out properly. I'm still working on converting these .mp4's to .ts files with the lossless audio from the disc, cuz since both these single layer mp4s and LG's DV demo ts files now work, I have high hopes for MrMC becoming the ultimate media center :)
Morten1969
Re: Dolby Vision
Post by Morten1969 » 23 Jun 2019, 05:23
when will mrmc 3.9.0 bee released
