Stuck loading source
L.Guilhas
Post by L.Guilhas » 19 Apr 2019, 22:09
I’m running MrMc touch 3.8.0 on ios 12.0.1 on my ipad pro 10.5 and found a weird bug. If for some reason I’m out of wifi or in airplane mode entering my library shows a loading screen but it just won’t load. I’ve waited a few minutes but it just stays there.
This is what I see:
https://pasteboard.co/IaUSYn8.png
If i hit cancel then i can see the source list but if i try to enter one like for example tv shows it says (it can not load network share). Obviously this is not a network share but a local folder.
If i then go to Files -> TV Shows it works.
It is as if the media source is being handled as a remote media source although it is local on my device.
Anyway to get around this?
Cheers
Re: Stuck loading source
Post by amet » 20 Apr 2019, 05:32
Let’s see debuglog when this happens please
L.Guilhas
Post by L.Guilhas » 20 Apr 2019, 09:04
You can find my debuglog here https://pastebin.com/raw/PwwAMBkK
My steps were (in airplane mode)
1) Start MRMC and wait a few seconds
2) On my home hit tv shows
2.1) stuck at videodb://tvshows/titles
3) Hit Cancel. The list of source appear (https://pasteboard.co/IaZajJV.png)
4) Hit tvshows on the new list
4.1) see cannot connect to network server (https://pasteboard.co/IaZaIaC.png)
4.2) hit OK
5) Hit in progress tv shows and see the same error
6) Hit on Files -> tv shows.
6.1) The list loads (https://pasteboard.co/IaZbBfo.png)
Hope this helps
Post by amet » 20 Apr 2019, 09:29
got it, should be fixed but I dont think it made 3.8.1 as we have already prepared that for release.
once we do new testflight round I can add you in for iOS testing
thanks for the report
