3.8.0 - Wrong display resolution reported  [SOLVED]
Montoya
Post by Montoya » 05 Mar 2019, 00:19
As already reported in TF thread, release version also reports wrong display resolution of my iPhone 7 Plus (1920x1080)
Re: 3.8.0 - Wrong display resolution reported  [SOLVED]
Post by amet » 05 Mar 2019, 03:13
That’s the resolution we get to work with , phone reports that as it’s virtual resolution.
See link for explanation for 6+ but it’s the same for 7/8
https://medium.com/we-are-appcepted/the ... 3dac5bbcb6
Montoya
Post by Montoya » 05 Mar 2019, 11:15
Thanks for clarifying the issue :-)
Didn’t know that down sampling was going on, on the plus models, so you guys could work with the virtual resolution !
