Youtube Add-on
Holger
Youtube Add-on
Post by Holger » 06 Aug 2016, 14:56
I want to request integration of the Youtube Add-on.
Reason
For movies it is possible to get additional movie information in the options. For many movies there is a link to a trailer. This link fails in MrMC because it requires the youtube add-on.
For good reason there no user installed add-ons anymore. So please integrate Youtube add-on as standard.
Holger
Re: Youtube Add-on
Post by davilla » 06 Aug 2016, 15:20
how above a vector to youtube app ?
Holger
Re: Youtube Add-on
Post by Holger » 06 Aug 2016, 15:45
davilla wrote:how above a vector to youtube app ?
Why not...as long as I am back again in MrMC Movie Information if I am leaving Youtube App it's fine for me :)
jbennett
Re: Youtube Add-on
Post by jbennett » 14 Aug 2016, 11:53
Holger wrote:I want to request integration of the Youtube Add-on.
Seconded.
The (broken) link to movie trailers seems to be a good example of one of many "phantom limbs" left in MrMC - exposed user interfaces to features that were rendered non-functional or completely gone when stripping out the verboten bits of Kodi (user plug-ins, etc).
I presume an ongoing goal of MrMC's refinement going forward will be to either add/fix missing/broken functionality wherever feasible, or at least remove or hide these "orphaned" UI references to avoid confusion?
Thanks!
Re: Youtube Add-on
Post by davilla » 14 Aug 2016, 14:32
Another path to youtube access has opened up. Stay tuned, work in progress as we say.
bleomycin
Re: Youtube Add-on
Post by bleomycin » 27 Aug 2016, 03:59
davilla wrote:Another path to youtube access has opened up. Stay tuned, work in progress as we say.
This is excellent. I registered just to say youtube is the one major feature I use the crap out of and currently keeps me away from MrMC.
bleomycin
Re: Youtube Add-on
Post by bleomycin » 18 Feb 2017, 02:16
Was just curious if this is still being worked on?
Re: Youtube Add-on
Post by davilla » 18 Feb 2017, 14:14
Yes but along yet another different path.
Re: Youtube Add-on
Post by timstephens24 » 18 Feb 2017, 15:05
Is there a way to use the YouTube apps on the devices?
Re: Youtube Add-on
Post by davilla » 18 Feb 2017, 15:17
timstephens24 wrote:Is there a way to use the YouTube apps on the devices?
Depends, on android one could send an intent with url to open. but that would leave you in the YouTube app instead of auto returning to MrMC after the item plays. iOS/tvOS did at one time have a way do the same but all attempts to do this have failed, something changed or it is no longer supported in the YouTube app.
