stephenh
Post by stephenh » 25 Jun 2019, 11:44
25 Jun 2019, 11:33
looks like I borked pvr :) new one brewing.
Keeps life interesting for us all anyway ...
Appreciate you cooking up a new one though! ;-)
Post by davilla » 25 Jun 2019, 11:53
stephenh wrote:
25 Jun 2019, 11:44
25 Jun 2019, 11:33
yea, actually tested pvr this time as amet is slacking off in the usa right now :)
We had a mini-devcon last week...
Post by davilla » 25 Jun 2019, 14:30
3.9.0 (190625.1110)
pvr repack
DC1983
Post by DC1983 » 25 Jun 2019, 20:13
25 Jun 2019, 14:30
3.9.0 (190625.1110)
pvr repack
Hi Davilla.
Thanks for the quick update.
PVR now loads, however on watching some channels the screen freezes and audio continues for a while then stops entirely. Issue is not present if I switch back to 3.8.1. If i disable videotoolbox the freeze does not occur. Running TVheadend Build: 4.2.8-27~g5c1b37b50 (if that helps).
I've e-mailed a log through to the support address.
Ted377
Post by Ted377 » 25 Jun 2019, 23:21
Everything works fine again for me.
TVHeadend Version 4.3-1792 ~ g466a01431
SET-TOP-BOX: Apple TV HD
FW: tvOS 13 (Beta 3)
Front-End: MrMC 3.8.1
SET-TOP-BOX: Apple TV 4K
Front-End: MrMC 3.9.0 (190713.1549)
NAS: QNAP TS-231P
Back-End: TVHeadend/PLEX
DC1983
Post by DC1983 » 25 Jun 2019, 23:32
Ted377 wrote:Everything works fine again for me.
Wonder if it's interlace related, I'm in UK and all our broadcasts are interlaced.
Ted377
Post by Ted377 » 25 Jun 2019, 23:43
DC1983 wrote:
25 Jun 2019, 23:32
Unfortunately, I can not tell you that either. I receive my TV via ASTRA 19.2.
NAS: QNAP TS-231P
Post by davilla » 26 Jun 2019, 02:01
DC1983 wrote:
25 Jun 2019, 23:32
Can I get a debuglog of ffmpeg codec playing a problem channel ?
Post by davilla » 26 Jun 2019, 02:28
DC1983 wrote:
25 Jun 2019, 23:32
Think I found it, interlace related was a good quess.
Post by davilla » 26 Jun 2019, 04:47
3.9.0 (190626.256)
fix regression with interlace check for h264
