Montoya
Post by Montoya » 24 Jun 2019, 22:30
24 Jun 2019, 22:12
Montoya wrote:
24 Jun 2019, 22:06
23 Jun 2019, 23:49
emby manual login
Can we have a 3.8.2 MrMC Store release with this fix (confirmed working on Emby server 4.2.0.19 beta), so I have a fallback MrMC version I can go to when beta fails (like now with most PVR's) ?
Right now, I can't upgrade my Emby production server (4.2.0.1), due to the log-in issue of the current Store version.
Also expect Emby stable 4.2 to be released within 4 weeks and I don't expect 3.9.0 to be ready by then, so it will affect all Emby Stable Users :!:
3.9.0 is on a hot roll right now, it's main purpose is the plex sort and dvdfab converted media fixed.
Unless something very bad happens, we expect a very quick testflight and push out for release.
OK, clear :-)
Everbrave
Post by Everbrave » 24 Jun 2019, 22:58
TvOS 13 beta 2
Emby Server 4.2.0.19 on NUC under Windows 10
Emby Server 4.2.0.12 on Synology DSM 6.2.2
Ariana
Emby client connects to Server .19 on NUC, the Home page loads correctly, TV shows loads correctly but the Movies library does not load!
Emby client works correctly with server .12 on Synology, incl. the Movies library.
Ted377
Post by Ted377 » 25 Jun 2019, 00:47
This Version crashes at start. Back to 3.8.1
SET-TOP-BOX: Apple TV HD
FW: tvOS 13 (Beta 3)
Front-End: MrMC 3.8.1
SET-TOP-BOX: Apple TV 4K
Front-End: MrMC 3.9.0 (190713.1549)
NAS: QNAP TS-231P
Back-End: TVHeadend/PLEX
Post by davilla » 25 Jun 2019, 00:54
Ted377 wrote:
25 Jun 2019, 00:47
are you running pvr ?
monkbolt
Post by monkbolt » 25 Jun 2019, 04:04
Plex sort order: it seems like some of the sorting options are gone, including the essential Date Added one.
Home menu/items: I can't see any changes here? I was hoping it would fix this issue.
stephenh
Post by stephenh » 25 Jun 2019, 06:34
24 Jun 2019, 21:08
MrMC 3.9.0 Testflight is live...
@davilla - Not a great release for me :-)
3.9.0 always crashes instantly on startup just after splash screen (I installed over the top of latest release 3.8.1).
Reverting to 3.8.1 "fixes" it ...
Running Apple TV 4K with latest tvOS 12.3.1.
Probably should try a "clean' install of 3.9.0 but a bit loath to blow away my settings until I see if a few more people start reporting it crashing?
stephenh
Post by stephenh » 25 Jun 2019, 08:04
@davilla
As per my crashes in previous message ...
I rolled back to 3.8.1, disabled PVR functionality (Settings/TV/General/Disabled).
I then installed the Testflight 3.9.0 and it did not crash on startup.
I then went back and tried to enable PVR functionality again (Settings/TV/General/Enabled) but then 3.9.0 crashed instantly back to tvOS home screen.
(I was then able to reinstall 3.8.1 and re-enable PVR mode again OK).
Ted377
Post by Ted377 » 25 Jun 2019, 09:51
25 Jun 2019, 00:54
Ted377 wrote:
25 Jun 2019, 00:47
Yes i‘m using TVHeadend.
Take a look at my signature :D
NAS: QNAP TS-231P
three6zerocool
Post by three6zerocool » 25 Jun 2019, 10:02
Also upgraded to 3.9 from 3.81 with PVR enabled. (Mediaportal)
It crashes on startup displaying the splash screen.
Reloaded 3.81 over top, and all is normal again.
Post by davilla » 25 Jun 2019, 11:33
looks like I borked pvr :) new one brewing.
