Post by cosmoxl » 23 Feb 2019, 17:15
Rootax wrote:
23 Feb 2019, 16:59
In mkv files, if I jump to next chapter, then the playback become very choppy.
I don't know if anyone already reported this. If not, I can submit a log file.
I'm seeing playback become choppy even while just watching but certainly after skips too.
Rootax
Post by Rootax » 23 Feb 2019, 17:37
Ok so here is the log about that :
https://pastebin.com/xHVyuCwf
maybe it's the : 18:32:20.082 T:158371538160 WARNING: Previous line repeats 4 times.
18:32:20.082 T:158371538160 ERROR: CDVDMsgGeneralSynchronize - timeout
18:32:20.090 T:158695634160 WARNING: CDVDVideoCodecAndroidMediaCodec: demux packets over-buffering
I launched MrMc, start playing a video (via plex client), jump to some chapters, went back some chapters, and bam, playing is chopper, like a 1 sec pause every 2 seconds. The audio is still fine. I've auto frame rate enabled. I've to say btw that auto frame rate cause sometime some stuttering too, and little desync between audio and video for 4k/hevc files, while it's perfect with the native plex client. My shield is connected with ethernet, 1gb/sec, iperf show it's pulling around 700mb/sec without problem. And it happens with low bitrate too so I double it's a network issue.
Post by davilla » 23 Feb 2019, 18:19
cosmoxl wrote:
23 Feb 2019, 13:45
koying wrote:
23 Feb 2019, 10:26
RC1 incoming. If you see bugs/issues, now is the time...
Those already posted and still present, please recap and I'll review.
I still see switching of frame rate a few seconds into the DVD rips even though the setting is on "start/stop" only. You should have been able to test this with the DVD rip I sent you.
I've looked at this sample. It starts at 29.97, then switches to 23.98.
MediaInfo says:
Frame rate mode : Variable
Frame rate : 25.664 FPS
Original frame rate : 23.976 (24000/1001) FPS
So even it is confused. I'm not sure what can be done. Picking the start frame rate would wrong for the rest.
Post by cosmoxl » 23 Feb 2019, 18:26
23 Feb 2019, 18:19
cosmoxl wrote:
23 Feb 2019, 13:45
koying wrote:
23 Feb 2019, 10:26
MediaInfo says:
Are we talking about the same sample? The one I uploaded is:
Video
ID in the original source medium : 224 (0xE0)
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings : CustomMatrix / BVOP
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : Variable
Format settings, picture structure : Frame
Codec ID : V_MPEG2
Codec ID/Info : MPEG 1 or 2 Video
Duration : 45 min 58 s
Bit rate mode : Variable
Bit rate : 5 079 kb/s
Maximum bit rate : 9 800 kb/s
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 24.257 FPS
Original frame rate : 29.970 (30000/1001) FPS
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.606
Time code of first frame : 00:59:59;00
Time code source : Group of pictures header
GOP, Open/Closed : Open
GOP, Open/Closed of first frame : Closed
Stream size : 1.63 GiB (92%)
Language : English
Default : No
Forced : No
Color primaries : BT.601 NTSC
Transfer characteristics : BT.601
Matrix coefficients : BT.601
Original source medium : DVD-Video
It is variable with some of the content (CGI) being 29.97fps but the live action being 23.976fps. Of course, then it's screwed up for broadcast and then maybe the only version they have is for broadcast so that's why even the DVD says original frame rate is 29.97. Trying to reconstruct it properly isn't trivial, I know. This particular sample I sent should see the AMC decoders start at 29.97 and then change to 60.606.
But, the main point I try to make is that the setting for adjusting resolution only on start and stop doesn't work so it either should work or be removed. :)
Post by cosmoxl » 23 Feb 2019, 18:35
Keep in mind I can just share my plex server with the devs for testing these videos. :)
nigelwalker
Post by nigelwalker » 23 Feb 2019, 19:12
Plex client keeps locking up its as if it's frozen button pressed on remote do nothing at all have to pull power
Post by davilla » 23 Feb 2019, 19:12
cosmoxl wrote:
23 Feb 2019, 18:26
23 Feb 2019, 18:19
cosmoxl wrote:
23 Feb 2019, 13:45
MediaInfo says:
Video
Format : MPEG Video
Codec ID : V_MPEG2
Width : 720 pixels
Height : 480 pixels
Color space : YUV
Bit depth : 8 bits
Language : English
Default : No
Forced : No
xinseo.mkv
Skunkworks:mrmc-private davilla$ mediainfo --Version
MediaInfo Command line,
MediaInfoLib - v17.12
start/stop works for me. video starts, it adjusts and will readjust if the stream changes, then back when stop
Post by cosmoxl » 23 Feb 2019, 19:16
23 Feb 2019, 19:12
cosmoxl wrote:
23 Feb 2019, 18:26
23 Feb 2019, 18:19
MediaInfo says:
Video
Format : MPEG Video
Codec ID : V_MPEG2
Width : 720 pixels
Height : 480 pixels
Color space : YUV
Bit depth : 8 bits
Language : English
Default : No
Forced : No
xinseo.mkv
No, that's not my sample. Another user uploaded that.
"Always" adjust resolution means what you described. On start stop means it does not readjust once it starts playing...until I stop. :)
Post by davilla » 23 Feb 2019, 19:21
cosmoxl wrote:
23 Feb 2019, 19:16
:) I was wondering about your sudden interest in that that type of content
semperfixd
Post by semperfixd » 23 Feb 2019, 23:17
semperfixd wrote:
23 Feb 2019, 11:57
koying wrote:
23 Feb 2019, 10:26
I have pushed you a file called "NCOP-1 (for ordered chapters)".
The issue is that
> With MrMC it skips frames (visible and is shown in the codec info.
EDIT: Logs: https://privatebin.net/?688644ae65ded08 ... pu85UrfAA= )
>No issues on Kodi 18.1
> No issue on PC
So the frame skipping only happens on MrMC
Problem still exists in the latest version. Dropping/ skipping frames.
