Post by cosmoxl » 16 Feb 2019, 12:58
koying wrote:
16 Feb 2019, 08:30
Ah yeah:
sink does not support passthrough of STREAM_TYPE_AC3 for 0 channels at 48000 sample rate
but it was doing passthrough before these betas even though codec info showed 0 channels for live tv.
Slice314
Post by Slice314 » 16 Feb 2019, 14:14
Is there any way to disable the "new mrmc intro animation"? It is causing all sort of problems on my Nvidia Shield, screen going to black, freezes, app crashing... I can only open it successfully one time out of 6 tries.
If you are not going to remove the new intro animation, at least, let us disable "that thing"
Post by koying » 16 Feb 2019, 17:47
It's coming. Not a fan of nice animated splash delaying startup myself ;)
SUPERBIF
Post by SUPERBIF » 16 Feb 2019, 18:24
I can't get Atmos working on the newest version available. Any way to get it working. It's only showing PCM on receiver not Atmos.
SUPERBIF
Post by SUPERBIF » 16 Feb 2019, 18:31
What can I do to get it working again. Can I install an older apk to get it working again.
Slice314
Post by Slice314 » 16 Feb 2019, 20:14
koying wrote:
16 Feb 2019, 17:47
thanks, some sanity over here :mrgreen:
SUPERBIF
Post by SUPERBIF » 17 Feb 2019, 07:53
Atmos is showing correctly now.
Post by koying » 17 Feb 2019, 12:44
cosmoxl wrote:
11 Feb 2019, 20:34
2) Display refresh rate adjustment doesn't obey the setting "on start/stop". If I use AMC decoders (surface or non-surface) on my DVD rips (those work with AMC surface now, thank you) it'll start off seeing them as 29.97fps, and outputting 59.94fps. But, after a few seconds some part of the process causes MrMC to see the file as 60.606fps and outputs 60fps. The variable frame rate DVDs (Star Trek Voyager) then look horrible during the film frame rate portions. It should go with what it detects at start, 29.97fps, and stay there as the setting implies. https://paste2.org/GeNsgKD2
I actually always wondered what "On start/On stop" was supposed to mean, but your interpretation makes sense ;)
P.S. Do you think it would be possible to get a sample containing such a framerate switch?
Otherwise, will be tricky to test...
jcwillia1
Post by jcwillia1 » 17 Feb 2019, 13:20
how do i stop mrmc from updating automatically?
Post by cosmoxl » 17 Feb 2019, 14:26
koying wrote:
17 Feb 2019, 12:44
cosmoxl wrote:
11 Feb 2019, 20:34
Do you want me to upload to the same web page as before?
