Movies tab not showing in Home Screen
Aymondo
Post by Aymondo » 20 Dec 2015, 19:39
After normally setting up MrMc...with one folder for TV and one for Movies, only the TV tab appears on the home screen.
To access my Movie library I have to go through Videos -> Files.
Any ideas?
krzysztof81
Re: Movies tab not showing in Home Screen
Post by krzysztof81 » 22 Dec 2015, 09:41
Had the same problem, while connected to external SQL database. Just rescan/refresh the sources and let the app do the rest.
If that's not the case, remove movies source and add it again. Try to keep your movie files in separate folder. If you mix them up with your TV shows, MrMC will only assign one tab to one folder, ignoring rest of the files.
Aymondo
Post by Aymondo » 22 Dec 2015, 15:59
Thanks for the reply krzysztof81,
I actually did try a refresh library scan and that didn't work. And yes I do keep my Movies in a separate Folder. Now I need to try to remove the Movie's source and re-add it. I just can't figure out how to do that! Removing a source on Kodi on my iMac is a simple right-click to get the Menu.
Can't figure it out on MrMc though.
Would appreciate the help.
Regards.
baerwurzl
Post by baerwurzl » 22 Dec 2015, 16:16
Perhabs you have hidden the "movies"-Button in the Skin-Menu (Settings)?
Post by amet » 22 Dec 2015, 17:46
Aymondo wrote:..... is a simple right-click to get the Menu.
click and hold select(touchpad) == right-click
Aymondo
Post by Aymondo » 22 Dec 2015, 19:53
Thanks a lot amet,
At first, removing the Movies source and re-adding it did not solve the problem. But when I tried deleting TV Shows as well and then re-adding both (Movies first) that did it. Now everything is in order.
Regards.
